Aluminum Ground wire with Copper Neutral/Hots
Gregj100
New User
Montana
Recreation
I have a Meter with 100 Amp service running #1 AWG aluminum Hots, Neutral and Ground to a sub Panel on a pole 100 feet away containing a Double Pole 30 Amp and 60 Amp Breaker. The 30 Amp goes to an RV Pedestal, the 60 Amp is not in use. I want to run wire from the 60 Amp Breaker to a existing panel on a 10x12 building 75 ft away containing four 20 Amp single pole breakers for lights/Receptacles along with a 20 Amp Double Pole Breaker for a 1500 watt heater. There will be no future upgrades.
When running the wire from the 60 Amp Breaker with #3 AWG Copper for the Hots and Neutral can I use #6 AWG Aluminum for the ground wire with the copper wires?
Should I change the 60 Amp Breaker to a 40 Amp Breaker for safety?
Thanks in Advance, Greg
The forum rules do not allow us to assist in DIY projects, you can try diychatroom.com
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
* This NEC� Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
