ZC'ya
- Colorado Springs, CO
New Member here. I am a third year apprentice, currently laid off at work, enrolled in an IEC school. I've been failed on an inspection, and I'm trying to understand WHY. At work, I have very little common electrician experience, most of my experience is in controls, circuit tracing, and troubleshooting. I have zero residential electrical experience. My parents live just down the street, and called me last week to inform me that their 1966 SquareD QO 100A panel smelled like it was burning. I rushed over to find that they had overloaded the main (dryer, a/c, oven all at once) and the main did not trip. The #2 Aluminum conductor insulation were melted, and the main breaker itself appeared to be slightly melted as well. I had the city come out and remove the meter, and they cut the service loose at the weatherhead. I was able to source a used breaker with the same part number and configuration, and I installed it with new #2 Copper Feeder wire to the meter. Inside the meter socket, there is only one lug in the center for the neutrals. I did not want to land copper in the same lug as aluminum (per 110.14) so I elected to just leave the #2 aluminum neutral in place. The city came back out, reinstalled the meter and reconnected us, told us to have inspected within 72 Hours. Inspector failed the installation, saying we could not use aluminum for neutral and copper for feeders. I have poured over my code book, and cannot find such a restriction. I fear that the only reasonable solution here is to shutdown again, and reinstall #2 aluminum for the feeders...but I can't see how that could be considered better in any way.
