i have no problem with the capabilities of aluminum -- if it is sized correctly and properly terminated it works fine --- i assumed the sub feed was underground --- 300 feet. with that in mind, and what i've seen happen to aluminum conductors in a wet locations -- and the statement temporary/"permanent" tells me this installation might be there for a long time? the bond in this case is the most important conductor in the sub feed -- the labor is the same --- i would go with a copper bond..............
