Question for everyone. We aren’t allowed to make copper to aluminum connections with proper connectors, so why are some newer lights wired with aluminum wiring and are able to wire to your standard copper wiring? They literally send you the orange wire nuts in the package. My question here is a little deeper. I’m wiring a new stacked oven that only requires 30 amps. The whip on the oven(from the manufacturer) is aluminum. The old oven has #6 aluminum ran into a 4 square(you know the typical blank plate, split bolt connection). I was thinking about using the split bolt connection again, with rubber tape and electrical tape, but the whip from the manufacturer is #10 aluminum. I don’t like the difference in wire size and feel like it could have a better connection. I was thinking about running 10/3 copper to it, but the aluminum whip from the manufacturer throws me off. What’s going on here? Are they not enforcing manufacturers to use copper?
