JohnDS
- Suffolk, Long Island
- Electrician
Hello guys,
Im just replacing a receptacle outlet and the old receptacle is attached with aluminum wiring. I know that when splicing copper wire to aluminum wire you need special wire nuts, but in this case there is no splicing needed. There is also no grounding wire so I plan to take a ground from the metal box.
My question is, is it ok to just reconnect the aluminum wiring to the new receptacle and it be safe? I dont need penotrox or anything do I?
