sparky37
New member
- winchester, va
When you use #3/0 AWG wire, what wire size ground do you need? Wondering because a hotel is using aluminum wire to power panels on floors to main panel which has copper in it.
The breaker size is what you are actually supposed to be using to determine the ground size but you didn't give that. If the 3/0 wire is oversized on a 100 amp breaker, you can go down a size on the EGC.
