Re: aluminum wire
My brand new "copper" self wired home is in a valley where 98% of the existing homes were wired in the 70's with alum. wire. I get the benefit of doing alot of work to the existing alum market. Where I have seen most problems is not in the joining of two alum wires under 1 wirenut, (the old joint seem to be holding up ok in almost all cases.), but the connections at the receptacle outlets, at the exterior walls are giving the most problems. Read this as moisture contamination. Also anywhere that sea spray air contacts aluminum wiring. Also what I see alot of is where attic j-box splices were made where there were way to many alum wires in a grey or blue wirenut, resulting in heat buildup and the wirenut plastic cracked right off. What I have yet to encounter is any evidence of electralosys from an alum to copper splice. I have never seen this ever, and have begun to think its largely a myth in real life. I still use purple wire nuts though because it keeps the local insp. happy to see them, and for legal protection , however I don't really believe they are any safer or non safer than standard tan twister wire nuts for the application.
