Just read a article (Wikipedia) on the new "Airbus 380" double deck airliner that will seat up to 850 people.
In order to save weight, all the wiring has been done replacing copper (the usual standard) with aluminum conductors (300 miles of it).
All of the electrical system is fully computerized and uses solid state devices instead of the usual contactors and breakers.
All cockpit lighting and display is "bulbless" LED.
The cockpit is what's called "paperless"....meaning that all the records, manuals, flightplans, data and instrumentation is completely digital.
Airbus places the blame for the delayed deliveries on the wiring.
Also, the plane's airframe (by weight) is made of 25% composite materials.
The riveting has been replaced with welded seams.
There was problems with wing strength during testing that was resolved by adding approx 30Kg (64 lbs.) of extra composite to the wing.
The hydraulic system pressure has been increased from the usual (standard for 50 years) 3000 psi to 5000 psi, which requires the hydraulic lines to be made of Titanium.
The braking system (reverse thrust) had been reduced to save weight.
The total take-off weight will be around 620 tons.
Travel anyone?
steve
Travel anyone?
steve
