geigerr
- Sugar Land, TX
I am building an enclosure that will be hosting vary of different electrical components for this instrument I am building. There will be a purge system attached to the enclosure to keep a constant positive pressure. The enclosure will be a stainless steel Nema 4x box. In the door, I am mounting a panel touchscreen computer that is rated Nema 4x/IP66. The chassis of the computer will be inside the enclosure. Outside of the enclosure will be a touchscreen monitor that is protected by 0.125" plexiglass with a 304 SS bezel. This piece of equipment will be placed in Class 1 Div 2 environment, will this be complaint?
Also, I am looking for a USB receptacle to mount on the door that is Class 1 Div 2 compliant, so I can plug a intrinsically safe USB memory stick to download data from the computer.
Just let me know your thoughts.
Thanks,
Robert
P.S. I am new to the field
Thanks,
Robert
