I have installed several standby generators. In most cases in my area there is no inspection required for generator installations; however, that does not change the way I perform my work. I am committed to meeting or exceeding code regardless of an inspection. My question is: Am I getting carried away when it comes to installing the ATS?
Many generator units are sold as a package which will include a 200 amp service rated ATS. Essentially, I am introducing a disconnect into and existing service which many cases is fed with SEU cable straight from the meter base. In these cases I remove the SEU, install SER and separate the neutral and ground wires in the electrical panel. Once that is done, I do not want to have a 4-wire service with 3-wire branch circuits (ie; dryer, range). Do I continue on with this process and rewire those appliances, too? I want to provide the safest and most code compliant installation, but I don't want to add unnecessary expense to the home owner when they just want a simple generator installed.
So, do you go through all of this effort, or do you just see the ATS as a means of connection for the generator to the existing panel and leave things be? I do not see how you can install a service rated ATS and not upgrade to SER - and then the above listed branch circuits.
Thank you in advance to whomever can be of assistance.
