captain skip
- New Hampshire
- Retired
I read through the ARRL Grounding and bonding book twice, I reviewed Mike Holt's excellent write up and I still can't figure out the answer to my question. Maybe someone here has already done this and can let me know what you did.
I'm moving my antennas from my attic to a detached garage. I'm planning on mounting a vertical VHF/UHF antenna and an OCF wire dipole on a metal mast that is secured to a bracket on the gable end of the garage. The wire dipole would run from the mast to a tree in the backyard.
I will run a ground for the mast to a new ground rod and as I'm going to run two feedlines into a duplexer I'll install two Alpha Delta lightning suppression units prior to the duplexer at the base of the antenna. These will be grounded to the new ground rod. That part I've got figured out. This is where it gets tricky - or at least above my pay grade. The garage has my workshop in it and has a 100amp subpanel tied into the main house breaker panel. The main breaker panel is grounded to an Ufer ground in the house foundation. The subpanel in the workshop/garage has two ground rounds, bonded together, spaced 6' apart already in place. I plan on bonding the new antenna ground rod to the existing ground rods. The 100amp subpanel is supplied with #2 wire from the main house breaker panel and has a ground wire going from the subpanel ground bus to the main breaker panel ground bus which is grounded to the Ufer ground as mentioned. Do I need to run an additional ground wire from the ground rods at the garage to the Ufer ground on the house foundation? It's approximately 100 feet from the garage to the house. I have a NM conduit that I'm going to run the feedline through from the antenna to the shack in the house but running an additional ground wire is not really an option as I would have to cut/dig up a paved driveway to run the wire - which the Commander in Chief would forbid.
Second part of the question - As mentioned I plan on putting two Alpha Delta lighting units at the base of the antenna. Do I need to put another one where the feedline enters the house too? Attached is a rough (very rough) sketch of what I'm talking about. The dotted green line on the bottom is the extra ground wire that I'm asking about. I also plan on running an RFI ground from the shack to a ground then bonding it to the Ufer ground.
