Re: ambient air temp.
quote
The air temperature inside and the air temperature outside will quickly come into equilibrium...
If equilibrium means they stop fluctuating, then I agree. If it means equal, I disagree. A local inspector put a thermometer in an empty conduit on a roof here in southern New Mexico, and measured over 130 degrees inside the conduit, on a day where the ambient was in the low 90's. Solar heat gain is the culprit.
Clearly the temperature that the conductor would be at before the input of current is 130, not 90. This will occur for as long as 6 hours or so most days, for over 4 months.
I would suggest there is no one way suitable for the entire country. Just like areas have different loading zones for line strength calculations, or lightning stroke maps, we could use a map, showing high solar gain, medium gain, or low solar gain factors. We could leave it up to the local AHJ. We could leave it alone. Seems like there is something in the 2005 recognizing conductor ambients higher than conduit ambient temps. I will look for it.
Jim T
