Re: Ambient Air Temperature
This is a reply from a fellow at askearth.com - thought it might be of interest.  He is not an electrical person - I'm guessing a physics teacher.  His suggestion is very much like the ASHRAE Handbook.
 Commented: Re the temperature/conductivity thing - I knew that if you got it cold enough you could make it superconduct, but I thought that maybe at more typical temperatures, an increase in temperature might increase the electron mobility and improve conductivity. Now I think about it a bit more, I can see that since it delocalisation of electrons among atoms in the "conduction band", any increase in temperature, by virtue of increasing the movement between atoms, may interfere with the efficiency of this transfer.
 As you say - the cooler the better.
 I wanted to clarify those points in order to figure out what a "reasonable" value for an ambient temperature might be. The standard seems to be based on the idea that this is constant - no so in this case.
 That is what led me to the idea of trying to see what your acceptable excursion from the nominal minimum capacity of the cable might be.
 My tentative suggestion is this:
 Simply using some sort of "average" temperature will probably take you out of spec on most warm days.
 Using the average maximum temperature would be safer, but still too risky (in my view) since (almost by definition) on half the days of the year, the maximum temperature will be above this value!
 Using the maximum recorded temperature should be a safe conservative temperature, since your cable would fall out of spec only if a new record was set. This seems too restrictive.
 My suggestions therefore is: for the locality in question, obtain the historical data for maximum daily temperatures, and derive a frequency distribution for this. Choose an acceptable "out of spec" probability - say 1 day in 1000. From the distribution of maximum temperatures, find the temperature that is only exceeded in average 1 day out of 1000 (or whatever), and use that as your "ambient" value.
 This is just my own line of thought, and like you, I would expect that there are some references to the "accepted" method. I haven't yet found any though.
 xarqi
