ambiguous arc flash sticker
megloff11x
We're making some equipment that will be 480 & lots of current. The actual arc flash hazard depends mostly on the available bolted current at the facility - which we have no control over and getting numbers is as pulling teeth in some locales.
What's the best way to label the machinery?
1. Generic arc flash warning but no PPE or distance info given.
2. Arc flash sticker with blanks for the customer to fill in with above info.
3. Above with values for infinite current calculation, and let the customer replace this with his own sticker showing values for his facility.
If you do a worst case infinite bus calculation, you may require spacesuits where none are needed.
The onus may be on those installing & owning the equipment to fill in the blanks, but I'd like to be sure that there is something for a warning label to start with in case they forget.
A second question, does someone publish a checklist of sorts telling you what warning stickers are needed where and what they should look like? When I did CE compliance, there were some fairly clear & well documented guidelines. Previous places mandated enough stickers to make the machines resemble a Nascar driver's suit & car - to the point where you were overwhelmed and distracted.
Matt
Matt,
When there is lots of bolted fault current, it generally results in the overcurrent protective device to act faster and results in less arc flash incident energy. The IEEE 1584 equations are very dependent on OCPD clearing time.
Provide the generic label as required by the NEC and let someone with local information provide calculated values as required by NFPA 70E. No sticker is required for calculated values.
I vote for a generic sticker. It satisfies the requirements without making you liable for information you don't have and that changes over time.
I 3rd the motion of generic stickers, unless of course they are paying you to conduct an arc flash study.
Sticker guidlines are in ANSI Z535
4th vote. We only provide the generic sticker to satisfy the NEC. From there it is our customer's responsibility.
Bob
5th vote for generics.
Codes change and you don not want to be responsible (liable) in anyway for a sticker that has too much info on it.
Who is going to run around and change all those stickers as codes change, anyway?
Per NFPA70:409.110
"An industrial control panel shall be marked marked with the following information that is plainly visible after installation:
(3) Short-circuit current rating of the industrial control panel based on one of the following:"[QUOTE/]
(see attached)
Additionally, I would include a lock-out warning label.
(see attached)
A good sign would be:
ARC-FLASH DANGER!!
OPENING THIS EQUIPMENT WHILE ENERGIZED WILL KILL YOU!! (insert picture)
ARC-FLASH DANGER!!
I like it! I do think only the 1st line along with Authorized Personel Only would suffice.
