Thanks for the help gar....
190209-0850 EST
Ravenvalor:
What is a gas regulator? Is it a solenoid valve? Is it a pressure regulator? Is it both? Is it a servo valve? Is it AC or DC? How much current? Are wires separate or in a cable? Why the need for a clamp-on?
What is the wire size to the regulator, and how long?
What is a gas regulator? It turns off gas to the grill in the event of a fire or the hood exhaust fan turning off.
Is it a solenoid valve? It is a solenoid.
Is it a pressure regulator? Do not know if it is a pressure regulator.
Is it both? Unsure.
Is it a servo valve? Unsure.
Is it AC or DC? AC 120 volts.
How much current? Unsure. Very low.
Are wires separate or in a cable? The wires are separate, a hot and a neutral.
Why the need for a clamp-on? So that we can check the current draw without turning off the grill during restaurant's busy times.
If we can check the current draw with the draw listed on the solenoid we can determine whether or not valve is fully opening or just partially opening. A clamp on milliamp meter will allow us to do this without shutting down the grill.
What is the wire size to the regulator, and how long? A 20amp, #12 gauge circuit is about 50' long in total length.
