Paul@Klapperichtool.com
New member
I have a machine shop in an industrial building with 400Amps of service at 480 volts. Currently, there are a bit more than 400 amps worth of breakers installed in the panel. What is the code regarding this matter?
I want to install 3 or 4 more machines to run off of a 100 Amp 480V Sub-Panel, but I don't know the code or recommodation for sizing breakers/fuses. Can I go 30% over or something like that?
Also, should I always fuse at the machine nameplate rating, or something less?
I suspect that this is probably not an easy thing to answer for certain. I am trying to get a feel for whether or not I need to hire someone to evaluate the situation, or if I can do something without causing a potential problem.
Paul Klapperich
Paul Klapperich
