Ampacities XLPE wire
Curious note:
Curious note:
On three of the MFR's spec sheets I reviewed each stated not for sale in the US, but is listed by the CSA. ???
No help, but I'm following post also for a answer, I've never used this type of wire..
More Information
More Information
MIL-W-16878/16 Military Hook-Up-Wire
Temperature Rating 125c
Voltage Rating 3000
Insulation Type XLPE
AWG Range 26 - 4/0
Gereral Cable
MIL-W-16878 Military Hook-Up-Wire PVC and Cross-Linked PE Insulated Wire
Don't foregt that MV terminations have to be teperature rated to match the current capacity, just as 90 deg C cable is used, but can't exceed the 75 Deg C column.
MV limit is higher, but just because you have 125 Deg C cable doesn't mean you can exceed the 90 deg C terminations. You can only use the higher current rating value for derating purposes.
