pparry7@yahoo.com
Can any one help me with which table to use for 200 amp sub feed conductors? Table 310.15(B)(6) or 310.16.
is 4/0 aluminum gould for 200 amp? Thank
pparry7@yahoo.com said:Can any one help me with which table to use for 200 amp sub feed conductors? Table 310.15(B)(6) or 310.16.
pparry7@yahoo.com said:whats the deal with 4/0 ser cable bieng rated at 200 amps? thats what we use for 90% of are sub feeds but I have a job with 2" pvc feeding a 200amp 120/v 240/v sub panel 250 mcm put's over my wire fill.
pparry7@yahoo.com said:I have a job with 2" pvc feeding a 200amp 120/v 240/v sub panel 250 mcm put's over my wire fill.
roger said:4/0 SER is not rated for 200 amps, see table 310.16.
It is allowed to be used for a 200 amp 120/240-Volt, 3-Wire, Single-Phase Dwelling Service, but this does not mean it is a 200 amp cable. See the text in 310.15(B)(6) as 480 Sparky mentions.
90% of your sub-feeds are in violation.
Roger
tryinghard said:Looks to me like 4/0 SER al is rated at 150A, see 338-10 & 334-80. I think this could be a problem if one uses a "farm" type 200A residential panel, it has feed thru lugs and about 8 space distribution, it would be easy to just run 4/0 SER to a sub panel but this sounds like a violation if the farm panel is mounted on the house.
Dennis Alwon said:As of 2008 ser must be use at 60C if it is used for interior wiring. 2005 still allows 90C
infinity said:#4/0 Al is rated for 180 amps. Those sub feeds would be a violation if the connected load was greater than 180 amps and protected at 200 amps. However #4/0 Al can be used to feed a subpanel if the connected load is 180 amps or less. This is due to the fact that 180 amps is not a standard size listed in 240.6 so the next standard size (200 amps) maybe used. This is under the 2005 NEC.
tryinghard said:Are you sure that's not the way I understood 338-10 & 334-80, so my post included 60 degree column
(4) Installation Methods for Branch Circuits and Feeders
(a) Interior Installations. In addition to the provisions of this article, Type SE service-entrance cable used for interior wiring shall comply with the installation requirements of Parts I and II of Article 334, excluding 334.80.
(4) Installation Methods for Branch Circuits and Feeders.
(a) Interior Installations. In addition to the provisions of this article, Type SE service-entrance cable used for interior wiring shall comply with the installation requirements of Part II of Article 334.
Dennis Alwon said:2005 NEC art. 338.10 says excluding 334.80 however the 2008 omits the words "excluding 334.80"
tryinghard said:Trevor,
How does this line up with 240-4(B)? If I have a calculated load at 195A I understand I can use a 200A OCPD with the 4/0 Al at 75?
infinity said:It's simple your calculated load cannot exceed the ampacity of the conductor. Under the 2005 SE cable can be used at 75 degrees C which would make it's ampacity 180 amps. You cannot protect this at 200 amps if the calculated load is 195 amps. You will need a larger conductor.
tryinghard said:Well 240-4(B) allows me to.
iwire said:No, read what Rob said, 240.4(B) allows you to use a 200 amp breaker, it does not allow you load the cable past it's rated ampacity.
