Hello.
I'm reading opinions about having to apply ampacity adjustment to conductors (cables) running through bored holes in lumber. Some say adjustments apply, some say as long as you can get the wire in with out damaging it your good to go.
I'm looking at inspector forums, this forum and other forums.
Is there a definitive yes or no answer on this.
I was asked to file for a permit on wiring that a previous home owner did throughout the basement (which also feeds first floor and exterior and ...)
That owner didn't pull any permits, and there was a foreclosure on the house.
For the sale of the house the new potential owners will need to get a permit and inspections on this wiring to get a CO.
I see some box fill problems, supporting, gfci etc. but for the most part, the guy (gal) did a clean job. My biggest concern is large bored holes with 20 or more nm cables running through them ( like across the ceiling going from one end to the other). Some holes also share coaxial and LV wire in them.
OK, another concern is all the splice boxes in the ceiling. He has home runs and switching, and multiple slice boxes through out up inside the floor joists. The floor to the bottom of the joists has to be about 6' 7". To me it looks like he was going to bury everything and put the boxes in the joist to get headed room. Maybe not ??? Maybe he did intend to leave it open, and just wanted them up inside so you wouldn't hit your head on them.
Thing is, how would an inspector see these boxes ??? But, first things first,
the bundled or not considered bundled nm wire.
I don't pull permits and have others do the work so I'm not sure if I will sign on for this.
If I did decide to, how might I attack the multiple wires through the ceiling joists. How would the inspector view these wires and if they should be derated (ampacity adjustified) or not considered bundled.
Thank you
Thank you
