Funny thing is in countries that use SI units for everything, the conductor size is in SI units which is primarily a base 10 system but their standard overcurrent devices are not base 10 type settings. They have 16 and 32 amp overcurrent devices - not sure if there is a standard rating in between those two. I would not be surprised if the 2.5 mm is considered a 32 amp conductor outside the NEC.
Not sure why he has 2.5 mm wire either. If not also marked in AWG there is a good chance it is not a conductor type mentioned in 310.104 and is not a NEC recognized conductor anyway.That is very possible but since the op stated 310.15 I assumed NEC. Not sure why he has 2.5 mm wire.
