Re: ampacity of a conductor
I agree with Irollo you can not figure the size based on the ratings of the breakers in it.
Try that with a 42 circuit panel filled with 20 amp breakers and you would need a 420 amp feed to the panel.
21 poles x 20 amps = 420 amps
You need to go by the name plate ratings, look at the name plate for minimum circuit ampacity or at least the total KW as Irollo has said.
