If I connect 1230A load to the 1200A MES298 CT with (1) 1/4"x5" copper bus. Is this C.T. undersize?
I mean it is 1200A C.T, connect to 1230A load, it sounds like undersize.
However, the bus ampacity is 1250A, it is good for 1230A load.
What about 800A trans-s feed 830A load? I do not know the bus size in the trans-s. Do I need to measure the bus size to determine if it is good or not? I never see a trans-s provide the bus size in the cutsheet.
The reason I ask if per NYC local code.
If I have 1200A C.T to feed (1) 1200A and (1) 30A service switch. Or I have 800A trans-s to feed (1) 800A and (1) 30A.
I want to hear your opinion.
