What are you calling the "unit". Air handling unit? Condensing unit? Packaged rooftop unit?dan316 said:What is the amperage draw of a 6 ton 3 phase Air Conditioning Unit? The voltage is 120/208.
Thanks
Looking at the nameplate would be the ONLY way I determine this...
Can you determine this without the SEER value?
Seems like when you ask the HVAC contractor for this information, they say something along the lines of, "Just run what you'd normally run for a 6 ton unit". :grin:stickboy1375 said:Looking at the nameplate would be the ONLY way I determine this...
mdshunk said:Seems like when you ask the HVAC contractor for this information, they say something along the lines of, "Just run what you'd normally run for a 6 ton unit". :grin:
"I decided to go with this unit instead"
I know there are some exceptions to this rule
