njshaw189
- Foster, Kentucky
I have two panels in an office tower that are giving me weird amp readings with an amp probe. The panels are 480/277v and its only one breaker in one panel on the third floor and two breakers in a panel on the fourth floor. The amp readings from the amp probe jump around the one breaker is a three pole 100amp breaker it jumps between 25 amps and 59 amp every second. The second breaker is also 100amp three pole and it jumps between 15amps and 40amps every second. The last breaker is three pole 30amp breaker that feeds a v.a.v. heater it jumps from 6amps to 22amps. I'm trying to figure out why this is happening i have never seen anything do this before. it not tripping or nothing. No other panel or breaker in the office complex does this so i'm sure it's a local issue. just confused
