highpowered
- los angeles
I have to show my calculations for 3 panels AIC/fault rating is sufficient. I’m changing out the 600 amp 4 wire 240/120v 4 wire (208v leg is on C) 3phase service because The main fuse is damaged and cannot Be turned off or on. Engineering will not let me submit this as maintenance(no new loads no change in amps) they have made me do full on plans. My final corrections are To show the 3 panels that are directly behind the switchgear(20-30’ of wire length) fault current is sufficient. Electrical engineer says because so close to panel it is not.
Ive done my due diligence and downloaded the excel sheet for this but for some reason i cannot input wire type or number of conductors? I would rather know the formula as I must show my calculations(point to point) anyway and I just want to know this moving forward?
Lastly any suggestions on continuing education for contractors in California ?
any help is appreciated
Thanks!
Jason S
Thanks!
Jason S
