bohl1076
- southern california
good morning,
i went to my friends home recording studio yesterday to try to trouble shoot his ground looping issues. heres what i found-
the room is on its own circuit, one of the receptacles is a "half hot" with 2-3ways switches, so i went into the switch box, one of the romex had no ground looks like someone had cut it back, the other switch's gound wasn't connected to any other circuit,and it wasn't the home run, so everything else was grounded except that switch but other then that everything appered to be isolated from any other circuits and their grounds. at the panel i couldn't locate any ground rod or cold water bond, although i'm pretty sure it's grounded some where. there was a #8 or #6 aluminum from the ground bar going somewhere inside the wall (cold water? rebar?)
he told me it happens reguardless of what room he has all his gear set up in. i also noticed everything he had wasn't "radio shack quality", but pretty high end stuff , and i asked him if he uses that same eqiuptment when he plays shows, and he said he does use the same stuff (on tour or at shows) without any problems
any thoughts or suggestions?
thanks,
john
thanks,
john
