I have to agree with Al, the waves of an AC voltage can be a spiral if the material it is passing through is large enough for the wavelength size, we only reference the wave from a small point that we can only see the sign wave as the wave pass by this single reference point, for a true 3-D image we would be looking at a spiral ball, think of an explosion under water, the shock waves would radiate out from the explosion point in all directions, just like radio waves do in the air when a plane transmits, the sign wave we use to represent AC is just the stationary single point of reference of the wave propagating out from its source, just because we tend to only take measurements from a wire, the sign wave we see is only relative to that point where we took our measurement, if we had a conductor that extended out in all directions from the source we would see this spiral ball radiating out from this source point, while the wave hight of a sign wave is relative to the voltage creating it, and the spacing of the waves is relative to the frequency of the voltage, don't confuse the wave hight with the wave length, as wave length is the distance between each wave in a sign wave as it is in a spiral wave hight is relative to the pressure of the wave or voltage, the 4th dimension is the speed at which the wave travels which is what really give us the frequency as if you were to move your measurement point down the wire at half the speed of light then the frequency would be half the 60hz or 30hz, this is why everything is only relative to the point at which we take our measurement, but if we could see the movements of the wave like we can with kinetic energy in water, we would see that same spiral that one would see in water.
