An Error message while running - Geometry error
Uri
United States
Hello all,
I'm new to NEC and this forum, so I apologize in advance if the issue had been brought in the past.
I try to run an input file in both NEC2 and NEC4.2 and I encounter an error message that terminates the execution.
It seems that for some reason the NEC is tapering the radius of the wire, without getting the command to do so.
The section in the input file that gives the error is:
GW 1511, 1, 0.263965, 0.000000, 67.360800, 0.263965, 0.000000, 68.034408, 0.0127
GW 1512, 1, -0.131982, 0.228600, 67.360800, -0.131982, 0.228600, 68.034408, 0.0127
GW 1513, 1, -0.131982, -0.228600, 67.360800, -0.131982, -0.228600, 68.034408, 0.0127
GW 1514, 1, 0.263965, 0.000000, 68.034408, -0.131982, 0.228600, 68.034408, 0.0127
In NEC2 the output is (corresponding lines):
176 0.26397 0.00000 67.36080 0.26397 0.00000 68.03441 0.01270 1 400 400 1511
177 -0.13198 0.22860 67.36080 -0.13198 0.22860 68.03441 0.01000 1 401 401 1512
178 -0.13198 -0.22860 67.36080 -0.13198 -0.22860 68.03441 0.00000 1 402 402 1513
GEOMETRY DATA CARD ERROR
In NEC4.2 the output is (corresponding lines):
DATAGN: STRUCTURE GEOMETRY DATA ERROR
Thanks.
I think we are talking about another NEC but, there may be an engineer here that can help you.
Roger
