Saturn_Europa
- Fishing Industry
- Electrician Limited License NC, QMED Electrician
The meter says its input is VDC, therefore there is some type of 'transducer' feeding it.Usually large CT(s) stepping down the amps to milliamps.
Maybe a rope ct with power supply? I think the CT’s on those are millivolt output, but probably could be configured as a dc output instead of data.The meter says its input is VDC, therefore there is some type of 'transducer' feeding it.
Most likely the transducer takes a CT (0-5AAC) input, although it may have some type of sensor input, like for a Rogowski coil, that actually measures the ground current.
