DIYhomeowner
New User
- Long Beach, CA
- Engineer
I want to add an extra outlet (external) on a circuit and am trying to figure out how many amps its rated for so I use the correct guage wire. Ive identified the breaker but there is no number on the switch. There is a paper label that says: 1 pole unit issue MG-5760 (possibly 5780- tiny print)
HACR Type
CTL type MH/
MM 120/240 VAC
Mount on vertical surface only
60/75 deg C. CU/AL
Torque
14- 20 18 lb/in
8 23 lb/in
6-4. 34 lb/in
Crouse-Hinds Co
If I cant get an answer Ill check the outlet Im tapping off from and use the same guage. I have no idea why its an HACR type breaker for this circuit, many of the breakers in my box match this one.
Thank you for your help!
HACR Type
CTL type MH/
MM 120/240 VAC
60/75 deg C. CU/AL
Torque
14- 20 18 lb/in
8 23 lb/in
6-4. 34 lb/in
Crouse-Hinds Co
