Ancient electrical connector
karn
United States
I found this old RV electrical tester. It appears to be missing the power cord, and the casing is riveted. Has anyone seen this style of connector/plug before? I was hoping to find out if it's 12-volt or 120-volt and if it's polarity-sensitive.
It looks like a polarized two-wire 120VAC inlet to me. You should be able to find a two-wire extension cord that fits.
Now that does not guarantee that they used this connector for 120V. I remember in grade school they had a movie projector where the speakers used standard two-prong 120VAC plugs, and so some student plugged them into the wall with a dramatic effect. :oops:
Yeah, I was assuming 120v, I might just have to drill out the rivets and take a look inside. I've been curious to peek at the electronics anyway.
That is NOT a 120 volt connector!
It is a two prong Cinch -Jones connector which we commonly use for vehicle voltage (typically 12 volts in the 60/70s). I used many of these is installing amatuer radio equipment into cars..
Now, whether the wide prong is + or - depends on who built the box. If one prong reads 0 ohms to case, pretty good assumption that is the - terminal, since there were very few (1956 Packard only typically for domestics, MG took longer to change) positive ground 12 volt vehicles.
And not ancient! Still in production. (y)
Thanks for the info, I couldn't get a reading to the case but the smaller prong reads 3.5 ohms to the ground terminal on the 7-way port.
They were also commonly used for loudspeaker connections before the 1/4" phone plug became the standard
They were subject to surface corrosion, especially when used outdoors, requiring an occasional application of WD-40 by amateurs and a deoxidizer by professionals.
As shown in Frank's link they are available is higher numbers of conductors too. All of them are polarized.
