xguard
- Baton Rouge, LA
"430.109 Type.
The disconnecting means shall be a type specified in 430.109(A), unless otherwise permitted in 430.109(B) through (G), under the conditions specified." [2014 NEC]
A molded case circuit breaker falls under one of the "shall be" types.
A branch-circuit over current device falls under one of the "unless otherwise permitted...under the conditions specified" types. (for motors 1/8 hp or less)
My question: If my branch-circuit over current device is a molded case circuit breaker (in a breaker panel) am I permitted to use it as the motor disconnecting means for motors larger than 1/8 hp?
I'm very confused by this section, maybe I have a screw loose, I appreciate most any responses.
