Nomadsparky
Hi, glad i found this forum, seems very helpful and informative!
Here's my question:
A customer's old furnace was removed and new baseboard heaters are installed(220V). I got called in to hook them up and will feed two rooms with 12-2. I'm wondering if you guys are running your feed from the panel to the t-stat box then down to the heater and from the same box to the other t-stat in the other room? Is it a better option to have a jb in the basement(feed) split up to both rooms(t-stat) then down to their respective heaters? And for efficiency/convenience, would a 4-pole t-stat be a better idea in disconnecting both legs or is a 2-pole stat sufficient?
Thanks
Cheers!
Here's my question:
Thanks
Cheers!
