mark32
- Currently in NJ
I've read a number of threads on this topic but I don't believe any quite cover my question. Lets say you are using a 6 space or even smaller panel, code says a detached structure needs a disconnect with a minimum rating of 60amps, however, what if you are only installing 6 or less circuits? Could you just come right out of the ground, enter the structure and feed the MLO panel and not have to back feed a 60a breaker or use some other type of disconnect?
