Another Head Scratcher
sparky76
So Cal
Relocated a cold switch fed J-box for vanity lite and the next week the H.O. says that the TV and alarm clock would go off for no reason. Also microwave clock would shut off, but that's on a dedicated circ. I go back and troubleshoot for 90 mins to no avail and nothing shuts off while I'm there. House is probably built in 50s -60s and 5 blocks from beach. Panel upgraded in the mid 90's. Any ideas?
wireguru
did you turn a breaker off when you did the work? could it be bus corrosion on adjacent breakers that were jostled when you turned off the circuit you were working on? did you open the panel? aluminum wiring? did you bump anything else anywhere? Is the microwave sharing a neutral with the other circuit?
mcclary's electrical
VA
Sometimes you have to really grill the owner. I had a homeowner tell me that after I wired her garage,,,,the bath fan upstairs quit working:roll:,,,,,my ppooint is this may or may not be true.
powerslave
Land of Lincoln
Exactly. Replace a GFCI in the basement laundry and two weeks later the garage door opener stops working. Or their cable goes out:roll:
