UGPee
- Seattle WA
- Homeamaker
Hi folks,
New to this forum, but need help on how to connect a 4 wires cooktop to 3 wires branch circuit.
the old cooktop was connected in this way:
My new GE cooktop also has 4 wires, installation manual says:
My question is can I just follow the way how old cooktop connects to branch circuit? Is the bare metal wire a natural or ground?
The branch circuit wires are seem like aluminum, must I hire an electrician to rerun the wire?Thanks.
cooktop branch circuit
Red black with red stripe
Black black
White+green bare metal
You must use a three-wire, single-phase AC 208Y/120 Volt or 240/120 Volt, 60 Hertz electrical system with separate ground. If you connect to aluminum wiring, properly installed connectors approved for use with aluminum wiring must be used.
3-Conductor Branch Circuit
When connecting cooktop to a 3-conductor circuit, connect the red leads of the cooktop and the power supply to the branch circuit red lead; connect the black leads to each other. Connect the green and white leads of the cooktop to the power supply and branch circuit neutral leads, which are white or gray.
