hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
A friend of mine asked me today about receptacles in an older home. Seems his son is selling his house that was built in 1924 and the buyer has a home inspection done. Mr. Home Inspector reports that there are about 10 receptacles in several rooms that are not 3 prong grounding. The buyer insists that they be replaced with grounding receptacles. The house is wired with old two conductor "snakeskin" Romex so there is no EGC.
Seller gets an estimate from electrical contractor #1 who said that the receptacles could be replaced with GFCI receptacles or GFCI breakers in the panel. Buyer will have none of that and will only accept a complete rewiring- per the home inspector.
Electrical contractor #1 quotes $8,500. I'm certain the walls are plaster on some kind of lath.
Electrical contractor #2, a smaller one-man outfit quotes $3,500.
I told my friend to tell his son to tell the buyer to go scratch. The Home Inspector has no authority and doesn't know what he's talking about. That house was built to the code in effect in 1924. There is nothing that says that electrical systems have to be upgraded to current code. The wiring is in good condition. Nothing needs to be done. I'm sure that most if not all of those receptacles will be used with two prong plugs anyway.
It's unfortunate that buyers believe that home inspectors carry legal weight and use it to hold the seller over a barrel.
And you wonder why I hate home inspectors.
-Hal
-Hal
