I am confused about what I read in my old book about transformers, "a neutral conductor, if required, is carried
from the primary, through the transformer, to the secondary". There is a picture of a transformer with the wiring
shown and visible are the primary terminals marked H1, H2, H3, with conductors brown, orange, yellow then toward
the middle you see a conductor with a white tape on it and its terminal has a bar of metal between/from itself and
the next terminal that has another conductor on it also with white tape. This is what I do not understand, the book
does not show a schematic but it looks like the neutral is coming in with the 480 VAC (as the book stated) and is
on a terminal that is connected or bonded with the terminal for the neutral for the output side. Would this mean
that the primary and secondary are no longer separated, I read out of this old book and the primary and secondary
are separated and use "mutual induction" to transfer electrical energy/step up or down, but they are separated
electrically. I am learning a little at a time. If anyone can help it would be appreciated. I do not have anyway of
scanning or attaching a picture of this book it was free, old half missing.
