electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
I just dont recall seeing them at the substation. BTW, my OP was worded poorly "....downstream a way after you built up some load" obviously the most load occurs at the beginning of the circuit.....y'all knew what I meant.
most of the time the loads are radial
you would need one on each branch
but one can serve all at the sub
each line is sized adequately for vdrop
but when all are loaded you get drop out of the xfmr
and rise when unloaded
more designed to compensate for xfmr drop
