After I posted that physics lesson, a simple analogy occurred to me. Let?s talk about distances. Let?s consider a group of cities that are all located on the same road. The road runs in a straight line from ?somewhere far West of here? to ?somewhere far East of here.?
? Someone tells you that the distance between the city of Appleton to ?that place somewhere far East of here? is 420 miles.
? That same someone tells you that the distance between the city of Nashville to ?that place somewhere far East of here? is 300 miles.
? For now, let?s believe what that someone said.
Here are some questions.
1. How far is it from Appleton to Nashville?
2. Did you need to know the name of ?that place somewhere far East of here,? or the exact location of that place, in order to figure out the answer to #1?
3. How far is it from Appleton to the city of Grover?
4. How far is it from Nashville to the city of Grover?
5. Did you need to know the answers to #3 and #4, in order to figure out the answer to #1?
Finally, make the following substitutions, and read through the material above one more time.
? Substitute ?potential? for ?the distance from a given city to that mystical place somewhere East of here.?
? Substitute ?potential difference,? or ?voltage,? for the distance between any two cities.
? Substitute ?one volt? for ?one mile of distance between two cities.?
? Substitute ?Phase A? for ?Appleton.?
? Substitute ?Neutral? for ?Nashville.?
? Substitute ?Ground,? meaning ?planet Earth,? for ?Grover.?
I don?t know about you, but I get an answer of ?120 volts? for question #1.
