Made right here in my home town.
The above only comes in single use packs. So I called AGS and the Dir. of Marketing told me that their Dielectric Silicone Compound was the same formula and came in .5, 1.25 and 4 oz. tubes.
AGS products are available through Ace Hardware, Do-It-Best and Tru-Value Hardware stores. If they don't stock the item, they can order it from AGS.
http://www.agscompany.com/lubricants/automotive/157
If you have any questions about a particular application, their contact # is below.
AGS
Muskegon, MI
213-733-2101
I am not affiliated with AGS in any way other than being in the same county. AGS has been a local employer for decades while the rest have all moved away and put people out of work.
There are reasons to use a product designed specifically for electrical connections.
Vaseline is petroleum and will burn and leave carbon arcs. Actually it is VERY flammable.
Some anti-oxidants have metal powder in them. They conduct electricity. Good for nuts and bolts. Not good for Edison bases.
Spray di-electric grease may have solvents in it or be flammable.
WD-40 will dry out over time and actually stick the bulb to the base after many years. WD-40 is not meant to be a lubricant. It is a water displacement chemical.
Ilsco De-Ox looks like a good choice if it's the 'plain'. De-Ox also comes in formulas with zinc or copper flakes in it.
