Panelboard. A single panel or group of panel units designed for assembly in the form of a single panel, including buses and automatic overcurrent devices, and equipped with or without switches for the control of light, heat, or power circuits; designed to be placed in a cabinet or cutout box placed in or against a wall, partition, or other support; and accessible only from the front.
If you look carefully, the whole thing appears to be made out of wood, or possibly Bakelite.That thing is pretty crazy. What is isolating the busbars from the can? Is the bottom busbar a non-isolated neutral? Is it service equipment??
Were panelboards always a manufacturered and listed thing? I ask because this thing almost looks like it might have been field assembled.
I totally forgot about that. I've seen pictures, actually posted in this forum, if I recall.I have some old disconnect switches in the backing is made out of slate or some other Stone.
This was recently I was going through my scrap pile, saw those and just wanted to pull out the copper bits. I didnt know the back was slate. I couldnt get some of the bolts out so I decided to wack it with a sledge hammer to see if that helped. It certainly caught me off-guard when the whole thing practically exploded into a million pieces!I totally forgot about that. I've seen pictures, actually posted in this forum, if I recall.
Typically made of Bakelite looks like this was custom made by a switchboard manufacturer. Many of these are still in existence in NYC. The rectangles are phenolic labels that can be engraved to identify the branch circuit fuse.I think I see now that the box is some kind if thick non-metallic material. What's with the rectangles that appear to have two screws from the back?
Just curious.
I have seen those back boards as slate, marble, bakelite, and asbestos.I always thought the backing was slate.
Yep, slate. Literally rock, drilled and formed to become the walls and back of the box. I've taken a few out, they are extremely heavy!I think I see now that the box is some kind if thick non-metallic material. What's with the rectangles that appear to have two screws from the back?
Just curious.
