mstrong1
New User
- Harleysville, PA, Motgomery
I have a situation where I want to run a truly insignificant length of non-plenum cable in a plenum and am wondering if there is any exception for this sort of thing.
I have a low voltage sensor installed in a ceiling tile, I need to run it to an interface box on the plenum side of the tile via a shielded 30ga wire jacketed in PVC. The total run is about 1 foot and the cable is less than 1/10th of an inch OD.
I can find plenty of 24ga wire that is rated plenum and am using that for the interface box to the destination, however anything over 30ga is too big to safely solder to the delicate sensor.
Any exception for a tiny bit of non-plenum cable ?
