ShockedOneinAZsun
- Yuma, Arizona
I was presented with a set of prints for an ICF home. (Insulated with Concrete and Foam). The walls are made up with a concrete center, plastic studs, and foam insulation on both sides. The walls are 12" thick.
The proposed method of installation was to cut out the foam and insert a 4 Sq, metal box with a mudring whereever a device goes, then use a chain saw to cut a 2 1/2" groove from one device to another, then install MC cable. I was told by the contractor that the groove would be tight enough, and it would be replaced by foam, that I would not even have to drill for, or install supports for the cable.
Has anyone done one of these homes, and if so, what are the pitfalls in bidding and doing this work?
