mrtom
- Chicago-Area
Had a service call the other day in which a homeowner showed me a standard Broan combination exhaust fan/light that he installed himself directly over the tub (something I think is a bad idea/design). To make matters worse, there is a soffit over the tub which brings the fan combo (and ceiling) just about 6" higher than the showerhead. I was told the bathroom counter-top GFCI feeds the fan combo and that it trips atleast once a week only while exhaust fan is running.
I confirmed all wiring was done correctly and GFCI outlet was working correctly. I advised that the problem could be a nuisance trip due to exhaust fan motor OR since exhaust fan is directly in shower area with such a low soffit that maybe steam/moisture from a hot shower was somehow effecting motor and therefore the GFCI.
Anybody else ever deal with something like this? I was going to change GFCI outlet and wait to see if the problem stops before having owner purchase an exhaust fan rated for a steam room or something similar.
Thank you in advance for any ideas!
