postgenerate
I would like to remove load from my A and B phases. I have an oportunity to use the stinger leg to Neutral or to A or B to run a single phase AC compressor. My current configuration is 3 phase 200A delta service.
I have
Voltage A to N = 120V
Voltage B to N = 120V
Voltage C to N = 208V
Voltage A to B = 240V (currently connected to unit)
Voltage C to A or B = 240V
My most desired connection is C to N as this will eliminate the entire load from my 120V lines. I understand I need a 250V i.e. not 120/250V breaker. Is there any reason why this configuration is ill advised?
A lessor desired but still better connection is C to A or B. as this will drop half the load but has the advantages it gives me 240V.
Suggestions?
Thanks!
I have
Suggestions?
Thanks!
