Any standard limitations for NEV value?
Saudia
Electrical QC Engineer
Is there is any standard value for NEV, for checking system is wiring is done in correct way.
What happen if NEV is 0 and also if huge value?
Unfamiliar with "NEV" .. can you elaborate
Neutral to Earth voltage. A result of the voltage drop on both the primary and secondary conductors on the line side of the main bonding jumper. When it is a high value, it is an indication of a problem on either the primary or secondary neutral.
