Any thoughts?????
SPARKS40
Northern Il
Okay....I recently wired up my rather small workspace/tool room in my residence.....6 receps, and 3 2-lamp 32watt T8 strips, each on their own switch, and all devices on one 20A circuit. I have a radio down there, which is fine with all of the strips, until i turn on the center strip, then the radio gets static, which i can only get rid of by turning the center strip off. The strips are Lithonia, all purchased at the same time.....Any thoughts, guys????
Sounds like a loose connection in the center strip which is arcing and causing RF interference. Maybe you should put it on an arc fault breaker and see if it trips.
No loose connections here....i guarantee it.....and what would an AFCI have to do with it?? Just curious....
I have a few....none of which will probably apply...but the the thought is there and you can't stop the freight train :D
Radio is so last millennium...do people still listen to the radio?
We have Satellite radio...mp3 players..streaming internet radio..etc
Ditch the mullet and get up to speed.
So was I right?
Did any of it apply?
:D
Did you check the pins' contact with the lampholders? Try wiggling the tubes while the radio is buzzing.
[6 receps, and 3 2-lamp 32watt T8 strips, each on their own switch, and all devices on one 20A circuit. I have a radio down there, which is fine with all of the strips, until i turn on the center strip,
Did you ground the strip fixtures and if you did check to see if you have a loose ground. I see alot of strip fixture not grounded...
It could be a bad ballast (yes, I know you bought all 3 new) Another thing that could cause a loose connection are those cheap plastic wire connector thingys (the wires are often not pushed in all the way at the Guadalupe factory):mad:
PS: Hope your not on the Am dial or you might have more work to do.:roll:
I don't think this is unusual. It seems to be common for me. Finishing a house, install the fluorescent closet lights, turn them on and the radio buzzes and what not.
My solution turn the radio or the light off.
Electronic ballasts cause interference.
So was I right?
:D
Yes, people still listen to the radio....in regard to the mullet.....I'm sorry your sister has a bad haircut.....
Hmmmm.....I've got it....seems that the fixture in question has a smaller, more resi grade ballast....i swapped them out, and no problem....shame on Lithonia. What gets me is that the price point is almost the same between the two fixtures....
I'm telling!!!!!
:D
Bad ballast could cause interference, but sometimes you get wires and metal fixtures together in the right length and you get an antenna effect. I would do the swap, and if the interference follows the light - it's either bad contacts (as someone else had suggested) or bad ballast. If it still happens when the "new" center light is on, you may have to reroute/change lengths on some of the wiring.
I like Celtics idea best - just get a satellite radio and be done with it.
