titan1021
- Northern California
I'm bidding a job where the sub-feeds are fed from Boltswitches at the main service. I didn't want to shut them down to pull the Boltswitch out while I was onsite, and now I am kicking myself because I can't figure out if the damn things use fuses or not. This is the first time I've come across them, my question is whether they utilize replaceable fuses. The sub-feed that I am dealing with is currently fed from a Boltswitch rated at 200amp 3 phase, I need to fuse it at 100a if possible to accommodate a new 75kva 480v transformer that will be feeding a new 200amp 208Y/120v sub-panel. I have searched online and haven't had much luck. The manufactures website says they use Class-T fuses but doesn't show them in place. Found the image below but it doesn't look like there is enough room for fuses. Any advice would be greatly appreciated.
Thank you.
Thank you.
