Is there anything against using the main-lug (of an MLO panel with backfed main) as the feeder lug to a downstream panel?
Am i violiating anything?
Picture this....
Using Square D's QO312L125G. which is a main lug 3phase panel.
I would use a QO3100 branch breaker with a holding kit PK3MB to be used as a backfed main.
(The reason I don't want to use the QO327M100, because I want the smallest box)
Then, since the panel's main lug is unused...I would use that to feed a 2nd panel, which will have a backfed main as well.
This is for an enclosed generator. Intention is one panel is on the genset, the other on the enclosure.
I want to separate the loads between the two panels (genset loads: ie block heater, battery charger versus enclosure loads: lights, space heaters)
Either panel feeds the other, depending on where the site electrician lands the building feeder.
Hope that makes sense and get a conversation going.
Thanks in advance.
Picture this....
Thanks in advance.
